Bruce_H_'s avatar
Bruce_H_
4WD Questions
I plan to purchase a new tow vehicle within the next two years. At the present time, I am towing a 3500 lb travel trailer with a 2006 Honda Pilot 4WD. The 4WD is Honda's name; actually, it is AWD with 80% front axle preference, and 4WD is only selectable in 1st or 2nd gear, and under 18 mph. However, the AWD feature has saved my bacon on two occasions when caught in unexpected snowstorms in mountain terrain when towing my previous trailer, a Chalet folding trailer.
Based on that experience, the new tow vehicle must have AWD or 4WD. I have researched Silverado, F150, Ram 1500 and Tundra pickups, and, frankly, I am disappointed in what I have learned about their 4WD capabilities. They are all part-time 4WD, meaning they must be in 2WD when on dry pavement, and can only be put in 4WD when the road surface is slippery enough to prevent binding. I really want something that I can put into 4WD before conditions turn bad, not after!
Am also considering full-sized SUV's. The soon-to-be-released Tahoe 4WD will be based on the Silverado and, I assume, will have the same part-time 4WD. The new Expedition will be based on the new F150--no indication so far about the kind of 4WD it will have.
The Sequoia has the ideal 4WD: selectable between 2WD and full-time 4WD, in which there is a center differential which prevents binding. It can be driven in 4WD mode on dry pavement. The problem with the Sequoia is that it is a really dated body design, and the second-row seats don't even fold flat, which is a necessity for us.
So far, I haven't found a solution to having a modern, full-sized tow vehicle with the option of full-time 4WD. Any ideas out there?
Hoping for some help here.
Thank you,
Bruce
  • Jeep Grand Cherokee and Dodge Durango. Also all of the part time 4WD pickups can be shifted on the fly any time. And can be driven on dry pavement in 4WD for short periods.
  • Our 2012 Silverado has full time 4 wheel drive and I might be mistaking but I believe the 1/2 ton Ram's and Ford's have it as well.
44,027 PostsLatest Activity: Mar 04, 2025
