billy1davisExplorerSep 15, 20195.9 Cummins Diesel Towing capacityMy owners manual tells me the max pin weight is 1200 and the 5vr (2007 Arctic Fox 27 ft) has pin weight of 1500lbs. On top of that the trailer is max of 12000 and the truck is rated at 9600lbs approxi...Show More
Cummins12V98Explorer IIISep 15, 2019You need to add a controller or lockup switch so 2nd will lockup. Your heat is from running in 2nd unlocked.
Related Content5.9 Cummins Diesel Towing capacity5.9 Cummins Diesel Towing capacityRam 1500 Towing CapacityOwning a Cummins Diesel?Used Cummins Diesel Questions
