parker_rowe
Sep 15, 2019Explorer
billy1davis wrote:
So what you're saying is when i put it in 2nd it will move to another gear like 1st?
No, he is saying the torque converter clutch isn't active in 2nd gear with the factory setup.
That means the converter is slipping and this heats up the fluid.
Convertors are suppose to "slip", so it isn't broken, per se. But the fluid will run a lot cooler if you lock the clutch in the torque converter when you are forced to pull hills in second gear.
Not sure what your options are to accomplish that in your year/model truck, but I'm sure someone here does.
44,070 PostsLatest Activity: Jul 01, 2022
