BarryG20
Sep 16, 2019Explorer
I had an 01 and pulled a similar trailer pin weight was closer to 1800lbs. It handled it fine. As mentioned the trans is the weak link in that truck (I had mine rebuilt well so it was no longer an issue for me). The cooling system is adequate if as someone mentioned the radiator is clean on the front. And as he mentioned pulling it out is the only real way to clean it as you just cant get to it good enough when it is in the vehicle. I used to pull mine about every 5 years.
