rhagfo
Sep 16, 2019Explorer III
billy1davis wrote:
My owners manual tells me the max pin weight is 1200 and the 5vr (2007 Arctic Fox 27 ft) has pin weight of 1500lbs. On top of that the trailer is max of 12000 and the truck is rated at 9600lbs approximate. I could change out the rear end to make it max out at 13000lbs. I have a chip and an extra cooler on the tranny which I had rebuilt. But coming up on steep and slow 2 lane roads i top out the temp on the tranny. Engine is fine but the tranny isn't.
NOt sure about getting a new truck or lightly used ot stepping down to a bumper pull'
Truck is 2001 Dodge dually 5.9l
Suggestions?
So if you want to pull that with your Ram it will need a lower gear ratio. I see that with a 4.10 gear the 3500 is rated at 12,900# towing. If you care you will likely be over the ridiculously low 10,500# or 11,000# GVWR of the Ram.
don't state if reg cab or Quad cab, 4X4 or 4X2?
These are the towing charts from the manual of our old 2001 Ram.
The best you can do is get a quality rebuild on the trans, with good additional coolers, and go with 4.10 gears and you should be ok. You might also put a small chip on the engine for a few more HP and lb. ft.
We towed a 12,500 5er with our 2001 Ram 2500, small chip and Bosch RV275 injectors, 5 speed manual and 3.55 gears. I would also add a PacBrake exhaust brake for extra stopping power.
