DWeikert
Aug 08, 2017Explorer II
What is this "shore power" of which you speak? Never used it. :)
But seriously...
Actually the opposite is true, if I understand what you wrote. A 50 amp service is going to have a 50 amp breaker. Sure, you can use an adapter to plug a 30 amp plug into a 50 amp outlet but that outlet is still going to have a 50 amp breaker. Just make sure your internal wiring up to the camper's breaker panel can handle the 50 amps should a fault occur. Think of your house wiring. You have a 15 amp circuit with 14 gauge wire. You can't just replace that 15 amp breaker with a 20 amp and leave the 14 gauge wire in place.
But seriously...
roamlab wrote:
it is much safer to step down from a 50-amp to a 30-amp than step up from a 30-amp to a 50-amp.
44,057 PostsLatest Activity: Mar 12, 2026
