Bedlam
Aug 14, 2017Moderator
Unless you are a heavy electric user, 30A will be sufficient. If you want to wire in 50A, use one leg for fridge, AC, heat, water heater and battery charger while using the other leg for every thing else. This will allow you to run your espresso machine, while toasting and still leave enough power to microwave. If you fuse each leg on its own breaker and do not gang it, overloading your second leg will not take down your essential circuits within the camper.
44,057 PostsLatest Activity: Mar 12, 2026
