You have a 20 amp extension cord that is hooked up to a 50 amp breaker! The only protection is the 50 amp breaker the campground supplies. You need breakers! A 50 amp main that feeds a 30 amp and one 20. Hard to do with the set up you have. To do that I would think you'd need a sub-panel.
I kind of did the same thing in my 30 amp camper. I removed the 30 amp cord and I added a 50 amp cord that powers a new sub-panel I've installed.
I feed 50 amps into that panel through a 50 amp breaker. Then I moved my A/C on one phase of that panel using a 20 amp breaker and new wiring from the sub to the old panel (where the a/c was hooked up). I run the rest of the camper off of the other phase with a 30 amp breaker using the existing 30 amp wiring.
I also ran an outlet off a 20 amp breaker on the same phase as the a/c so I can plug in an electric heater. You'd never use heat and a/c at the same time anyway. Works great! No more popping the 30 amp main. If I go to a campground that only has 30 amps I have a adapter I can put on the end of the 50 amp cord so I power up both bars in the sub panel with the same phase. Never had to do that but I could if I had to. We just camp where there's 50 amps.
