hohenwald48
Jan 02, 2017Explorer
fpmtngal wrote:
I stand corrected -the outlets are similar but not the same. I was judging more from the experience of a friend of mine who had an electrician install his 30 amp RV service, and who hooked it up to 240 volts, thereby doing expensive electrical damage to his RV. Another person I know said it was a common error and to make sure I checked mine before plugging my RV into it, which I did and found that it had been installed correctly.
In any case, 50 amp is not 240 volt.
Actually, 50 amp RV service is 240V and in fact some high end RVs actually use 240 volts to operate some of their appliances. Most 50 amp RVs only use the hot-neutral 120 volts and not the hot-hot 240 volts. However, the 240 volts is available for use from a standard RV 50 amp supply circuit. A 50 amp circuit can supply 100 amps at 120 volts or 50 amps at 240 volts (or a combination of the 2) for a total of 12,000 watts.
A 30 amp circuit can only supply 30 amp 120 volt service for a total of 3600 watts.
Again, be cautious when getting electrical advice from a web forum.
44,067 PostsLatest Activity: Jun 05, 2026
