Unfortunately, your picture is no a 50 to 30 adapter. Looks like a female 30 amp and a male 30 amp.
myredracer wrote:
Using a 50-30 adapter is perfectly safe due to the 30 amp main breaker in the converter panel inside an RV. I believe some older RVs do not have one tho. These adapters are CSA listed and if they weren't safe, they wouldn't be on the market.
The 30 amp receptacles get a LOT more abuse from users not turning the power off when plugging in (via the breaker) and yanking cords out. Sometimes they are so bad you need a stick or duct tape to hold your plug in place. I have seen pics of shore power cords melted and burned beyond recognition from bad connections at a pedestal.
The converter in an RV has a high momentary inrush current when initially energized - you can hear a zap and in the dark you can see a flash. If you plug in live all the time, it causes pitting on your shore power plug blades which in turn attracts dirt, eventually causing poor contact, overheating and possible eventual meltdown. Same thing inside the 30 amp CG pedestal recept. which can get pretty crispy looking inside and have poor contact. Loose contact pressure inside a recept. caused by yanking cords out too often along with pitting inside a recept. can cause a high resistance connection and low voltage.
Plugging into a clean and tight 50 amp recept. can avoid problems if there is one available. Sometimes you will find only 30 amps available in a CG if it's busy and you can be stuck with a bad pedestal. Some older CGs only have 30 amps available throughout. In this case, you can use a 30 amp to 30 amp 18" "extender" dogbone adapter like the Camco 55205 in the photo. This way, if your extender's plug goes up in smoke and flames, you will hopefully only lose your $20 extender. We carry one around now.
Another thing I've found is that some pedestals won't allow you to fully insert your plug into the 30 amp recept. because the plug housing hits the pedestal enclosure which can cause/add to problems. We are at a Thousand Trails right now that has a new pedestal installed made by Heritage and our Conntek plug only goes in part way (about 3/4?). This would be another reason to plug into 50 amps.
