Procrastinator
Aug 12, 2019Explorer
Bionic Man wrote:
Glad things are working well for you.
Do you think the Ford anti-sway system would be adequate with a standard hitch in place of the Hensley? They are not the only manufacturer using that type of system, I would think there is something to it.
I think the Ford anti-sway would be fine for anything but a Hensley or a pro-pride. As you get into the engineering of those two hitches, you will learn about the "Hensley bump". It's important to have the trailer brake prior or at lease the exact same time as the truck. If not you will get the bump. The Ford anti-sway uses the truck's brakes to stop the sway. I don't know if or how much it uses the trailer brakes. All I know is the hitch works great when not handicapped by the ford system.
