Groover
Aug 12, 2019Explorer II
nickthehunter wrote:Groover wrote:Clicky
Several comments on here about using E-rated tires. Just for general information if you special order a 4wd F150 you can get it with load range C LT tires (LT 267/65 18C) for $295. This is much easier and may be less expensive than swapping tires on a brand new truck.
Interestingly though, the 2019 Towing Guide shows that you have to have 20" tires to get the max rated tow capacity. I have not been able to find out what the tow capacity is with 18" tires of any sort and my dealer can't tell me.
I am not sure what you are trying to show me but I was referring to all the blocks marked with footnote 9 which says 20" wheels required. What would those numbers be if you don't opt for the 20" wheels? Of course, I am mostly concerned with the 3.5 Ecoboost with max trailer tow package which gets the 3.55 rear end.
