richclover
Aug 15, 2019Explorer
mhamershock wrote:Groover wrote:
The top tow rating for the 2019 F150 in the clicky above is with the Supercrew, 6.5' bed, 3.55 rear end 2wd and it is 13,200lbs. The line below it for the max payload package (3.73 rear end) shows 11,700lbs. So, you actually lose 1,500lbs towing going with the max payload. Granted, you probably want it for the tongue weight but that is not what the Ford book shows as top tow config.
You can spec out a 2019 F150 Lariet with max payload package, just click on the 3.73 axle. But you do still lose access to a lot of other options when you do that.
For some reason I can't share the link to the build and price as a clicky.
https://shop.ford.com/build/f150/?gnav=vhpnav&intcmp=hp-rvv-bpbuild-f-150&hptid=fv-2598-hp-se:rvv:na:na:Ford%20F-150#/config/Config%5B%7CFord%7CF-150%7C2019%7C1%7C1.%7C500A.W1E..N1...SS6.XL6.53C.55A.CCAB.RETAIL.T8C.LAR.%5D
I rarely care about tow rating. I care about payload. I'd never pull 11,700 with a 1/2 ton, not even my HDPP. Most of us tow TTs or toy haulers or some such, and hitch limits/RAWR numbers are the top issue. When I was shopping I wanted a payload of 2500 lbs, and only the HDPP would proved that with the options I wanted.
Tow ratings and payload are one thing ...
My little Nissan, now traded and gone, was rated to tow 6100#, 610# tongue wt. Factory tow package. Payload not a problem with the 3300# loaded flatbed trailer I need to tow. All well within limits, trailer brakes included.
But... That poor little V6 motor just couldn’t handle the load ;)
