Mr__C
Apr 17, 2021Explorer
50amp EMS w/surge
Will The EMS-PT50X 50amp EMS operate properly if plugged into 30amps? Need to know before I commit...No response from Progressive Ind.
Gdetrailer wrote:
:R
Connect L1 and L2 together on a proper 120/240 circuit and see what happens..
L1 and L2 are 180 degrees "out of phase" compared to each other and even the neutral and that IS correct.
When L1 is going in positive direction L2 is going in a negative direction. When L1 is going negative the L2 is going positive.
And there is ZERO "wrong" with what I posted.
The problem you have is "semantics".
There are 30A to 50A dogbones that only supply L1 with 120V connection and there are 30A to 50A dogbones that will connect both L1 and L2 to the single 120V 30A power source..
As I told the OP, all they can do is try it, if their dogbone does not connect both L1 and L2 together then their EMS will not allow voltage to pass..
However a REAL "EMS" in theory should not allow ANY voltage pass that has the exact same direction waveform on L1 and L2 as that is a violation..
