SoCalDesertRid1
Dec 16, 2013Explorer
The truck's computer is probably confused as to why the stock tank keeps staying full when the truck has been using fuel. Maybe there is a programming fix for the gauge, available from the aux tank manufacturer?
Or maybe you will need to eliminate the gravity feed valve and use a pump and filler nozzle system instead, so the stock tank only fills when you fill it, like filling at a gas station, instead of staying full all the time.
44,026 PostsLatest Activity: Feb 24, 2025
