Busdriver
Feb 13, 2016Explorer II
6.0 chev
Is anyone towing heavy 11'000 lbs with a 3500 Chevy . Thinging about new truck don't want a another diesel.
alexleblanc wrote:
the low end torque just isn't there and makes for much more of a strained towing experience.
alexleblanc wrote:
I will say as a side note though that next to the big diesels out there the next best thing is the 3.5 Ecoboost, that's what we really need to start seeing in 3/4 ton trucks for the gas option.
kw/00 wrote:
If u had owned one and pulled with it then you would know that power on paper is not always true......just saying
kw/00 wrote:
The test that I have seen including the IKE test prove the GM 6.0 ain't no slouch compared to the other offerings. Like said above buy one and pull with it. The GM 6.0 has come out on top or at least number 2 in most test out there. if u had owned one and pulled with it then you would know that power on paper is not always true......just saying
Kalabin wrote:alexleblanc wrote:
The 6.0 is really the weakest of the gasser options out there, while it may get the job done I'd give the Ram 6.4 or Ford 6.2 a serious look for better performance. Othet than the gas engine itself, the 2500/3500 SRW gm truck is a great platform
To be fair when your talking about these gas engines in any of the HD trucks the power on paper is splitting hairs. The 6.0 has done very well across the board because of the 1-2 gearing on the transmission. All of the HD trucks finish within seconds of each other on the pick up truck tests, excluding the IKE Gauntlet which the Ram 6.4 ran in 1st gear @ maximum load ratings which hardly any of us will ever do with these trucks.
I have towed with a Ford 5.4, 6.8 and Chevy 6.0. They all get the job done, and the biggest improvement was the 6-speed transmissions behind them. I would test drive each and every HD trucks and find the one that you enjoy the most and go from there.
As others said I have towed 7,000lbs with my now sold Chevy 2500HD w/ 6.0, 3.73 gearing and 6-speed transmission. Once your up to speed it moves right along, on hills it would spin @ 4200rpm as it's designed to do. If I were doing 11,000lbs I would shoot for the 4.10 gears.
ksss wrote:alexleblanc wrote:
The 6.0 is really the weakest of the gasser options out there, while it may get the job done I'd give the Ram 6.4 or Ford 6.2 a serious look for better performance. Othet than the gas engine itself, the 2500/3500 SRW gm truck is a great platform.
I tow 10k with a Diesel and until they offer the 3.5 Ecoboost in the Super Duty I won't switch to a gasser, the low end torque just isn't there and makes for much more of a strained towing experience.
Buy one and pull with it and then talk about it. The 6.0 may be the lesser powered pickup on paper. However in actual pull offs it does very well often besting the competition. I have gone over scales weighing at 30K combined and taken that load from 5K to 7,5K and it pulls very well. The pickup handles the weight well, the tranny never got above 220. I don't know how the other gas trucks pull, but the 6.0 is a good pulling gas motor. Does everything you could reasonably expect a gas engine to do, pulls well beyond its ratings.
