rrev's avatar
rrev
6.0 GM question
Excuse me if this has been posted before because it probably has and I just haven't been able to find it but I'm an apples to apples kind of a guy.
I'm looking at buying a new tow vehicle to pull my camper; 28 ft TT, weighs about 7200lbs. We pulled last year around 5500 miles but I drive this truck 12 miles to and from work every day. I have done the math and it just doesn't pencil out where it's justified to own a Duramax with fuel prices being what they are. I'm just trying to make sure I'm right.
So here is my question. Honest answer please. If you own a 6.0 GM, what year and specs are your truck, what it your trailer size and weight, why type of terrain do you tow on, and mpg; towing and normal, and do you feel it's enough truck.
I'm just trying to make the best possible decision. Thanks in advance!!!
  • 2012 2500hd 6.0 3.73 6 speed 6l90e tranny.
    I tow about 8000 lbs with it and usually head through central VA into WV so most of it is low altitude mountains. It does very well and gets maybe 8-9 mpg. Just set the cruise at 65 and steer. It might wind up to 4k rpm on the 6% climbs but otherwise it runs at 2300 in 5th on the flats to small hills and 3100 in 4th to get up the moderate hills.
    I am very satisfied with it and I would not call the 4.10 a must have for towing with the 6.0. It probably won't let you hold a higher gear that often so most likely you will be in the same gear just turning a few hundred higher rpm.
  • Btw - you may find it very difficult to find a 4:10 6.0 on a dealers lot. The standard is 3:73 with Max tow rating of 9,500 lbs. The 4:10 is a $175 factory option. I had to order my truck.
  • You can see my set up in signature below. My fiver weighs 12,280 scaled and loaded. A 4:10 axle is a must have with the 6.0 for towing anything over 9000 lbs. I love my set up and the 6.0 performs well for my needs.
  • western PA with an '04 3.73 rear. towed a 5k tt and a 9-10k f'ver.
    towed the tt like it wasn't even there, towed the f'ver great but sucked gas getting 8-10mpg on the turnpike and could only go about 150 miles before I had to fill up.
    A newer 6.0/6 speed with a 3.73 woudl be great just make sure you get a 2011 or newer to get the 36 gallon tank. the weight you're pulling will be fine with a SBC
