x96mnn wrote:
If your looking at Ford and want a 3/4 ton got F350, the F250 is more like a half ton then a 3/4. The Ford Eco boost with max payload gives you more.
Please. Sure the Eco HD is great, but my F250 is not like it. I have 2976 lbs of payload, a 10,000 lb GVWR, 22,000 GCWR, bigger, full floating axle, bigger brakes, bigger cab, better engine braking going down hill, etc, etc, etc. also, the only difference between mine and an F350 is the spacer block over the rear axle, the badge on the fender, and the yellow sticker that allows it to legally load/tow more. So if the OP has a good deal on an F250, I say jump on it. I love mine!
Oh yeah, one more thing. Try finding an F150HD on a dealers lot. Scarcer than hens teeth. You want one you gotta order it. F250's however, can be found easily.
