ib516
Aug 02, 2014Explorer II
6.4L Hemi tow report - weights added
Towed 550 miles over two days. 5er is completely loaded to max gvwr, even had fresh water on board. I'm going to say it was about 12k#. I ran through hills, up mountain grades, into stiff winds and through lots of rain.
It ran in 5th gear most of the time at 2100 rpm @ 65 mph. Into head or side winds it would drop into 4th to maintain speed. Grades would require 3rd gear at about 3k rpm, and once I hit the mountain grades I saw 2nd gear at 5k rpm a couple times. Temps were all in check, including transmission.
There was only a couple times I couldn't have accelerated if I wanted to, and that was when I had to drop into 2nd. Interesting that it can do 60 mph at 5k rpm in 2nd.
Mpg was 8.1 over the two days, as low as 6 into the wind and as high as 12 when it was behind us.
Very happy with how it performed.
