Engineer9860 wrote:
Is anyone using Shell Rotella in their 6.4L Ford Power Stroke?
My last company truck was a 2004 6.0L PSD. We had used Rotella and after many, many problems we switched to Motorcraft 15w40 at the recommendation of our Ford dealer. My current company truck is a 2008 6.4L PSD. We continue to use Motorcraft in the current truck. The reason we switched was in response to issues we kept having with the HPOP on the 2004.
Since the 2008 doesn't have an HPOP I'm thinking of switching the '08 to Rotella so I can use up some old stock I have laying around.
Has anyone used it? Should I be concerned by switching back?
Thanks,
Eng.
The problem with the HPOP on your 2004 was the pump design itself and had nothing to do with the type of diesel engine oil you were using.
Your 6.4PSD requires a CJ4 API rated diesel engine oil so any brand that has this rating will be fine.
