Sjm9911
Dec 16, 2020Explorer
Dadoffourgirls wrote:Sjm9911 wrote:
... I will let you all know how it handles in the snow with factory tires in a few days. I have to go into work during the storm over here and im sure if we get a foot or two of snow it will not get cleared. Not sure if i will add weight to the bed yet. I might just see how it handles by itself. It seems heavy enough to get traction without adding weight. But im still undecided as getting stuck is not on my to do list.
I would add a couple hundred pounds. I think that makes the difference for snow traction. I ran between 200 lbs and 400 lbs last winter based on when I needed to feed the Goats or put salt in the water softner.
Unfortunately, i will not get to drive it in the snow. At least not yet. Got called in early so was at work before the snow started and will leave after its done. I really wanted to test it out.
44,071 PostsLatest Activity: Aug 16, 2026
