rowekmr
May 20, 2015Explorer
6.6L Duramax-Lift Pump Suggestions
Hello
I recently got a 07 Sierra 2500 classic with 140K on the LBZ (pre DEF) engine and have encountered low rail pressure code P0087. After reading about the various sources of this problem I have read and heard that many install lift pumps for long term durability of the fuel system and to eliminate the code. For anyone that has had that code or contemplated/installed a lift pump which model/design you went with? Did you modify the tank inlet/pick up? Encountered any pump failures?
Thanks
Thanks
