eHoefler
Jul 17, 2016Explorer II
depending on load, terrain, and outside temperature, I have seen as high as 30* degrees above engine temperature. keep in mind, engine oil is also used as a coolant in a desiel enginge. in the cummins, it has nozzles that spray oil up into the bottom of the pistons.
44,071 PostsLatest Activity: Aug 16, 2026
