RCMAN46
Mar 31, 2019Explorer
"They also operate at lower engine rpms, which lowers the piston speed. Pretty much an irrelevant negative on the I-6!"
If you are comparing the Cummins with the Duramax then you are dead wrong.
Here are the facts.
The Cummins makes its peak torque at 1800 rpm
The Duramax makes its peak torque at 1600 rpm
The Cummins makes its max horsepower at 2800 rpm.
The Duramax makes its max horsepower at 2800 rpm.
So much for the popular belief that the I6 Cummins operates at a lower rpm than the v8 Duramax.
So the statement that the Cummins operates at a higher piston speed holds true when comparing to the Duramax.
Here are the facts.
44,071 PostsLatest Activity: Aug 16, 2026
