- Turtle_n_PeepsExplorer
Durb wrote:
Better torque characteristics
What does that mean? - Grit_dogTrailblazerHere comes the fanboy stuff now.....
Soonerwing, either one will be comfortable, durable and have gobs of power. Period. Cummins12V98 wrote:
They sell the 6.7 to RAM but they also sell the same engine to others for Medium Duty applications. "True medium duty"
But the latest cummins uses the Bosch CP4.2 HPFP and now uses hydraulic lifters. Crickets...
Same goes for the Medium Duty AISIN transmission as it's used in many other MD applications.
Nissan Titan XD medium duty? Crickets...
Oh and Medium Duty Rams end up on Ford lots in various ways :B.... Crickets...
- ktmrfsExplorer IIIboth are very high quality reliable motors. IMHO don't let the engine decide your brand. Drive both and pick the one YOU like the best, not the one someone else likes. YOUR the one going to be using it.
- Cummins12V98Explorer IIIHere is another thing to consider. What does CUMMINS do??? They build engines!
GM's D Max is used by what other Medium Duty Manufacturers? "Crickets"
"ALLISON" (GM Built), who else uses that trans for MD applications? "Crickets"
Well let's add another thing to chew on. Simply look around out on the Highways. What brand DOMINATES the "Independently Owned" RV and HotShot hauling market. RAM, there is simply no comparison.
Oh, they use them a lot to haul Fords. ;)
- memtbExplorer
4x4ord wrote:
RCMAN46 wrote:
Longer stroke engines have higher piston speeds.
They do. And with only 6 cylinders that Cummins has to have much bigger, heavier pistons and rods flying around..... it's a wonder a 6 banger can even compete with a V8. :)
They also operate at lower engine rpms, which lowers the piston speed. Pretty much an irrelevant negative on the I-6!
Anyone questioning the reliability and power of the Cumins vs the V8’s should spend a few minutes watching (YouTube). the annual Diesel Power Challenge, held every year near Denver, Co. if you like “coal burners” you “WILL” be entertained and amazed! - ACZLExplorer
I love a V8 as well, but disagree with your last portion of your comment. Look at all the semis going down the road. Wether it's Detroit, Mack, Volvo, PACCAR or Cummins, they are all I6's. Shoot, look at what's out in the cropfields as well. Again, John Deere, Case, New Holland, they too are I6's - 4x4ordExplorer III
They do. And with only 6 cylinders that Cummins has to have much bigger, heavier pistons and rods flying around..... it's a wonder a 6 banger can even compete with a V8. :) - 2001400exExplorerLots of information and actual data here.
https://news.pickuptrucks.com/2018/07/whats-the-best-one-ton-heavy-duty-truck-for-2018.html - GulfcoastExplorerI grew up with Chevy's of every kind, that's all we would buy.... until I found a Cummins 5.9 diesel.
