ShinerBock wrote:
DirtyOil wrote:
Baw haw ha!! This coming from the self appointed RV.net clean air freak... what a Hypocrite! If your are the so-called expert on emissions, you would know the OEM intake is as good as it gets. As stated earlier, unless your willing to do the whole show... but as you so loudly pointed out in other posts... your just "adding to NOx polluting gang" of "coal burners", Good luck Hypocrite!
Or maybe your just doing this to stir up the hornets nest?
I usually don't post during the weekends because I have better things to do, but I have better things to do. If you would follow my post them you would know I used to work for Cummins. Taking a silencer that is meant to keep the sound of the turbos down is a big difference from deleting your emissions equipment. I suggest you research the difference so you can actually benefit this conversation.
Baw haw ha.... Again... "I got the modding fever again and deciding the stock intake tube with its silencer is keeping me from some power and from hearing my turbos sing." "
silencer is keeping me from some power " and you use to work for Cummins.... now we know why "you use to work for Cummins". I did read your post... your the one claiming the silencer is for lack of a better phrase "robbing you of some power"...LMAO "expert".... too funny!
