- mudfuel07ExplorerI don't think you will regret it. I have had no issues with mine.
- Showme_5vrExplorerI want to thank those of you that have replied. It appears that when ordering a 2023 RAM 3500 SRW Crew Cab long bed that the HO upgrade is now almost $4000 more not the $2800 it was for the 2022 model year. So we have gone with the regular 6.7L Cummins Diesel.
- IdaDExplorer
FishOnOne wrote:
Me Again wrote:
Lets see, GM went to the Desmo pump as the CP-4 pain was to much for them. RAM reversed back from the two years of CP-4 failures. Saw a new 5500 with 9,500 miles with failed CP-4. Guess who still uses the CP-4?
Here is a picture of the 5500 being unload at RAM dealer.
We now know the CP4.2 pump doesn't tolerate air in the fuel especially after a fuel filter change and guess who didn't use a lift pump?
Cummins used a asymetrical CP4.2 pump and they were failing like crazy and tried to switch to a symetrical pump but it was too late. Guess who doesn't use a asymetrical pump?
You can package a turd anyway you want and you've ultimately still got a turd. I wouldn't buy a vehicle with a CP4 in it. - FishermanExplorerYa well we all know about Fords. CP3's are now being switched out on a recall.
Cummins used a asymetrical CP4.2 pump and they were failing like crazy and tried to switch to a symetrical pump but it was too late. Guess who doesn't use a asymetrical pump?- Me_AgainExplorer IIILets see, GM went to the Desmo pump as the CP-4 pain was to much for them. RAM reversed back from the two years of CP-4 failures. Saw a new 5500 with 9,500 miles with failed CP-4. Guess who still uses the CP-4?
- Cummins12V98Explorer III
rhagfo wrote:
southernsky wrote:
Yes but watch out for the exploding fuel pumpbucky wrote:
That depends on the year model and whether or not a CP4 injection pump is involved.
Well Ram decided to go back to the CP3, and issued a recall on all 2019 and 2020 Rams with the CP4 to replace with the CP3.
"Everyone is calling it a CP3, but it’s actually a CP-ISB21. It’s certainly not the same CP3 that was used in 07.5-18" - Grit_dogNavigator III
Derp! - Cummins12V98Explorer III
For model years 19 and 20 they were stupid and went with the CP4 and they realized it was a bad ides. They are replacing all of the pumps on every one of those trucks at no cost to the customer.
. - the1admanExplorerI have owned and towed 15K plus with both. The HO does it better and the Aisin is better loaded, but its not by a large margin. I think starting at 15K and above the HO makes more sense. Also my HO gets about 1-2 MPG less in most situations.
44,056 PostsLatest Activity: Jan 19, 2025
