BarneyS
Jan 10, 2020Nomad
How do you guys get it out of the heater in your home? My water heater is in the basement and there is not enough overhead clearance to get the anode rod out without destroying it. To get a new one in, I had to disconnect the entire heater and tip it on its' side so the anode would slip in the hole.
What am I missing or doing wrong? Does anybody make an anode rod with a hinge in the middle? I can see two joined together with some kind of eye bolt like a Numchuck. Is that kind available anywhere?
Barney
Edit:
Found one here !
Barney
Edit:
Found one here !
44,068 PostsLatest Activity: Jun 21, 2026
