jdc1
Jan 16, 2020Explorer II
ScottG wrote:
You can probably add an electric heater to your existing WH via the drain plug.
If the propane part is the only problem, it could be a cheap fix for you.
"Hot Rod" is what you are looking for here. It's a simple install. Saves you time and money over a conversion.
44,068 PostsLatest Activity: Jun 21, 2026
