Does the drain plug have the same thread size as a new std size element found at Home Depot or Lowes? Why not use a standard element ?? Cannot be adapted ??
You must have an Atwood water heater. The only element that will work is a Hott Rod which is not recommended by Atwood to be used in their tanks. Hott Rod
