Does the drain plug have the same thread size as a new std size element found at Home Depot or Lowes? Why not use a standard element ?? Cannot be adapted ??
Previous owner(s) installed a Hott Rod in my Atwood and it works great. Only problem is you lose the drain plug and in my case the element and associated plug cap jams up against the gas regulator and piping and is a PIA to remove if it is desired to drain.
