Does the drain plug have the same thread size as a new std size element found at Home Depot or Lowes? Why not use a standard element ?? Cannot be adapted ??
Why cant you tap the 3/4 inch drain hole to 1 inch and install a normal household water heating element (110) volt. ? Forget the warranty !! Thanks again for your comments.
