JCR-1
Aug 24, 2013Explorer
6 Gal Hot water tank
Does the drain plug have the same thread size as a new std size element found at Home Depot or Lowes? Why not use a standard element ?? Cannot be adapted ??
westend wrote:JCR-1 wrote:There may not be enough material around the hole that comprises the threaded fitting. I know my old WH has just an adequate fitting welded onto the tank, enough for a 3/4" fitting.
Why cant you tap the 3/4 inch drain hole to 1 inch and install a normal household water heating element (110) volt. ? Forget the warranty !! Thanks again for your comments.
