Bank_of_Dad's avatar
Bank_of_Dad
6 speed transmission questions.
So I came out of the ice age and got a Suburban with the new 6 speed transmission (PRNDM_1). Reading the manual, it seems a little daunting.
So how do you use it when towing? And what about steep downhill grades (short or long) when towing. I'm used to just downshifting into 2nd.
Thanks
Judy
  • I use manual a lot in my Duramax when towing heavy. It runs cooler when I do the shifting.
    In my 2500HD with the 6.0 I have yet to use the manual function when towing heavy. I use tow/haul and plant the right foot to the carpet.
  • Thank you Texan, T/H on the end of column.
    Downtheroad, its much more interesting getting comments here than reading the manual:)
  • 6 speed..GM automatic - does it have a button on the shift arm or on the column for Tow/Haul?
    If so, just use 'D' and Tow/Haul when towing.
    Did your Burb come with a manual in the glove box?
  • I tow TT or Horse Trailer about 6000. TT has Equilizer brand sway bars on it.
  • Excellent transmission. 99% of the time when towing, select D and T/H mode then let the tranny do the work deciding what and when. It has a built in transmission brake when T/H is selected and mine will hold us(10K trailer) at 60 MPH on a 7% downgrade for over 5 miles. When climbing a grade, if you are not satisfied with the speed, select M and then what ever gear you feel will do the job at a reasonable RPM. this transmission is so much better than the 4 speed it isn't even a close comparison.
  • Depending on the load, you may want to (M)anually select 4th or 5th for the top gear you will be using. Set the tow/haul mode and you are ready to go. It will downshift going downhill as needed.
