TomG2 wrote:
Hybridhunter wrote:
....snip...... It only limits up-shifting, ........................snip...........
Funny, mine downshifts with a tap. I often anticipate the extra power needed to climb a hill and tap it down a gear to save the transmission from doing it for me half way up the hill.
Of course it does, if you are in a gear above the gear you tapped down into. If you are in 6th, and you select 5, it will force the downshift. But if you are in 4th and you select 5, it probably will not do anything.
Basically, the same as the old 1-2-3-D setup. If you have it in 3, it will shift thru gears 1, 2 and 3, but will not shift into 4th (or od or D or whatever you want to call it). It is simply less cumbersome to have a button to select range rather than have 6 individual positions for the gear shift lever.
The operation is quite different from an auto with true manual shifting capability, such as my Subuaru or the Acura TL we used to have. In my Subaru, if I select 3, it will will stay in 3 unless I let the speed get to where it cannot physically maintain the gear. I can stand on the gas, and it will not downshift. In my '10 Suburban, if I select 3 and step on the gas, it will downshift to whatever gear it needs to respond to my request.
