time2roll
Nov 13, 2019Nomad
2oldman wrote:6V L16 is even larger at 445.jdcellarmod wrote:Your 6v batteries are rated *each* at 300ah? Most I've ever seen is around 220.
I'm planning on having 2-6 volt batteries with a 300 amp hour rating. ... I do not have room for 4-6 volt batteries...I'm not opposed to using 12 volt batteries.
For the OP... some get by on 200/300 amp hours and run a microwave but it will be marginal. Might get an alarm if the batteries are cold in the morning and a bit low from running the furnace all night.
Give it a go if that is all that fit. Worst case get a Panasonic inverter microwave where it actually heats at a lower power setting as selected instead of just cycling the megatron on and off.
44,068 PostsLatest Activity: Jun 21, 2026
