work2much
Nov 13, 2019Explorer
2oldman wrote:jdcellarmod wrote:Your 6v batteries are rated *each* at 300ah? Most I've ever seen is around 220.
I'm planning on having 2-6 volt batteries with a 300 amp hour rating. ... I do not have room for 4-6 volt batteries...I'm not opposed to using 12 volt batteries.
Some here believe that 12v batteries are better for high-amp inverter applications. Perhaps some big 12s would be better.
2-6v batteries will be a struggle with a microwave.
For a 300ah rating each would have be 300ah. Connected in series the amperage doesn't double just the voltage.
If a 6v battery was rated at 300ah, 2 in series would make a 12v 300 ah battery. Conventional wisdom is to discharge only to 50% for better cycle life so in the end you would have a 12v 150ah usable amp hour capacity
Discharging at a .3C rate would be about 1200 watts which should be ok with a battery bank that size.
44,068 PostsLatest Activity: Jun 21, 2026
