crosscheck
Nov 13, 2019Explorer II
ajriding wrote:
If you are new to RVing then consider an alternate power source. If you only camp once per year then no biggie, batteries will die of old age before you can consume them, but using batteries to power up heaters, hair driers, ovens or other high power appliances will cost you a lot in batteries eventually.
btw, discharge to 50% is not going from 12 volts down to 6 or 7, check the charts. Down to 11 volts is a dead dead battery and past 50% discharge.
Inverters are dangerous in that they will run down your batteries quick. Batteries only have so many cycles of charge/discharge before they are no longer able to be charged back. GC batteries are superior to Marine Rv batteries and can take more cycles, but all will succumb to cycling to death.
From more of a full-timer or part-timer RVer standpoint:
A small 2,000 watt generator is little less than double the price of the two batteries, but should last forever. You just put gas into it.
By comparison, If you charge your batteries off your alternator then you are still putting gas into having available power it just goes un-noticed.
Solar can keep the batteries topped off, but will not provide enough power to run 2,000 watts (unless you have 2,000 watts of panels up there pointed directly into the sun). Solar recharges batteries, and assuming you use a little power here and a little there then 200 watts (not 2,000) solar can keep up, but if you use more than the panel is supplying (mayb on one 150 watts from a 200 watt panel) then u are still cycling the battery from charge to some level of discharge so using up the battery lifespan.
By your reasoning,all golf carts should have gas engines because frequent cycling of batteries will over the years cause the batteries to die. But why do most carts run on batteries? More and more campgrounds are restricting Genny hours. Many of these true deep cycle batteries have 500 cycles which depending on how often you camp and charge your batteries, could last anywheres from 5 years to eight before replacement. At $200 for 2 6v GC2 over 5 years is only $40/ year. We dry camp most of the time without running the Genny and it is because of hard working, deep cycle batteries, an inverter, plenty of solar and some charging when driving.
Dave
44,068 PostsLatest Activity: Jun 21, 2026
