SoundGuy
Mar 05, 2017Explorer
martinandanne wrote:
I have one of these NOCO 5 Watt Solar Battery maintainers. Assuming I have two 6 volt batteries in series to product 12 volts, am I correct that I would still use a 6 volt controller despite the fact the output from the batteries is 12 volts?
If you already have that solar panel you've linked to you don't need anything more - just hook it to the two 6 volt batteries which are connected in series and are in effect a single 12 volt battery. Question is - why bother with such a tiny panel which outputs so little as to be almost meaningless. :h
44,068 PostsLatest Activity: Apr 17, 2021
