Oldtart's avatar
Oldtart
60k Budget truck and camper
Hi There
New member here although have been lurking for quite a while.
Soon looking at becoming a solo full timer.
I'm newly retired this year and my plan is to go the truck camper route for the flexibility in getting in places easier then a motorhome
As stated in the subject line I'm going to try to stay around 60k for the truck and camper.
Both used of course.
So that I don't look back later and wish I'd chosen differently my thoughts are to go with a 1 ton dually
I'm thinking 35-40 for the truck and the balance for the camper.
Does that sound reasonable for a package that could give me comfort and reliability for some years of service.
Need good four seasons capability in the camper.
West coast guy here and plan on going southerly at times but also have lots of connections in coastal Alaska so could see myself traveling that way as well.
Anyway I know it's a broad asked before question but looking for input on truck and camper choices in the used market based on above.
Thanks!
  • OP, was that 04 a short bed or long bed?
    If short bed, I haul essentially the same camper on the same truck. Long bed would put some of the weight on the front with a 811 and be better, but you're smart in figuring your tolerance for sway.
    FWIW the setup in my sig on OE alloy wheels and 3700-3900lb rated tires has hauled the camper many miles on and off road, dirt, rocks, gravel bars in a river, cross winds in the prairies pretty admirably. (For me. Yes a dually 3500 or larger would get rid of more sway and have more factor or safety in the wheels and tires, admittedly.)
    And YES if I was full timing or used the camper a lot I'd have a camper that size on a dually. But I've got only maybe 10,000miles of hauling the camper since 2013 and the camper only leaves the shop once or twice a year. The other 50 weeks a year a dually is totally overkill for me.
  • Actually you can put huge discs on earlier model trucks, you're not limited to drums.
    You just have to run 19.5 wheels. You can even run 22.5 semi truck wheels if you want, the hub adapters are about $1000. But the original brakes on even an earlier one-ton are perfectly fine. You shouldn't go down mountain passes riding the brakes anyway.
    The problem with that truck/camper combo you drove was being single-rear-wheel.
    I've owned several different single rear wheel trucks and several duallies. It doesn't matter what you do to a single-rear truck, it's never going to have the confident, stable handling with a camper that a dually has.
    Skip the expensive learning curve others have done, get a dually. It's the only right way to haul a big camper.
    Single rear wheel trucks can haul big campers "adequately". But not as well as duallies. If camper carrying is the truck's main purpose, why would you even look at singles? That makes no sense at all.
  • You should be a able to get a long-bed extended cab gas truck new, for the low $40k-ish.
    Easily doable.
    I guess because I'm still learning.
    But I get it
    But I get it
    We all learn... I'm hoping to save you the expensive learning curve!
    The single-wheel/dual-wheel debate is an old, hashed and re-hashed debate.
    It's good that you drove that single wheel rig that even already had stability upgrades, because the first time you drive a dually with a camper you'll immediately feel the difference.
    I get it, some people don't want a dually for their daily-driver pickup (although my last four have been) but if it's primarily a camper hauler, wider is better.
    Easily doable.
    My 2017 F-350 DRW Super Cab 4x4 6.2L gas V8 was under $41K. Just brought a 3650 pound Bigfoot home from Dallas to Atlanta and the truck handled the camper great.
