Freep
Aug 30, 2017Explorer
6v or 12v?
All else being equal, which is preferable and why?
2 220 AH 6v batteries
or
2 110 AH 12v batteries
or
srschang wrote:
Wow, what a coincidence. I just installed 2 gpl-31xt 12v batteries in may camper a week ago. I also installed 4 100w solar panels & a Xantrex 2000w inverter. I just went out to the camper & ran the microwave for 3 minutes on the inverter. It used 4.6ah of juice at 85 amps in the 3 minutes. To put it in perspective, my single cup Keurig uses 125 amps for 45 seconds, then 70 amps for one minute to make one cup of coffee on the inverter.
Scott
Freep wrote:
PianoTuna, thanks for the detailed explanation. This makes me wonder if I would even be able to run a microwave for a few minutes with 2 fully charged Lifeline gpl-31xt 12v batteries.
I really wish the LiFePo batteries were more mature(and cheaper). The reason I settled on AGM is that by the time the AGMs need to be replaced, the LiFePo batteries should be a lot cheaper and easier and also have some built in protection from trying to charge when they are too cold.
Freep wrote:
....but I also have a gen and I hate using it because it's incredibly loud.
pianotuna wrote:
Freep,
For about 10% of the cost of the fuel cell you can have a solar charging platform and batteries that will give you more power.
One of the problems with fuel cells is that they require ultra pure fuel. That's fine if you are NASA and nothing else will work.
pnichols wrote:
Don,
Concerning ultra pure fuel for fuel cells ... is that true for propane fuel cells? If so, where are us RV'ers going to get ultra pure propane? (I suspect that part of the high price for propane fuel cells is a super filter/dryer for the incoming propane.)
P.S. Of course solar by itself is not as close to the ultimate solution for anywhere anytime power replenishment that a propane fuel cell is. I guess the ultimate solution would be solar plus a propane fuel cell keeping an AGM or lithium battery bank automatically charged 24/7. ;)
