Freep
Aug 30, 2017Explorer
6v or 12v?
All else being equal, which is preferable and why?
2 220 AH 6v batteries
or
2 110 AH 12v batteries
or
Freep wrote:Post the converter model number for best suggestions.
I don't how the battery is charged now when the gen is running or when I'm plugged in. I do remember seeing some device in the basement wired between the gen and something. I'll have to check that out.
rjxj wrote:
You cant compare a 12 v gp dual purpose battery to a gc2. As covered in the last go around compare a Trojan SCS225 to two T105
Oldfordman wrote:
Biggest advantage to a pair of 6v batteries for a 12V system vs single 12V is the plate size in the 6V. It will stand up to more charge/discharge cycles as well as supply high currents with less plate damage.
GordonThree wrote:cewillis wrote:
I'd rather have (and do have) multiple 12v. If one is no good, you're still in business. And with the specs you mentioned, it's 220AH at 12v either way.
X2 for 12v
work2much wrote:jimh425 wrote:
People are in favor of 6V for less cost for same capacity/durability. Disadvantage is that you need both batteries to power your system.
I have no reason to switch to 6V batteries currently since either system works for my purposes.
It's true but a decent battery that is maintained with proper monitoring and charging is a pretty reliable source of power whether it's a pair of 6v or a single 12v. These are essentially the same aside being connected by cables vs encased in a piece of plastic.
Could one 6 volt battery fail completely and render a 12 volt system unusable? yes, but I don't think it is any more likely than a 12 volt battery losing individual cells.
