Freep
Aug 30, 2017Explorer
6v or 12v?
All else being equal, which is preferable and why?
2 220 AH 6v batteries
or
2 110 AH 12v batteries
or
Freep wrote:pianotuna wrote:
It depends.
My own preference is 12 volt. I do that because I run a medium size 3000 watt inverter.
This is interesting. How does the inverter figure into this? At some point I'd like to add an inverter too. The hope is to one day be able to run the MW for a few minutes without running the gen.
time2roll wrote:
Alright!
Honestly I would try to just not use the 12v fridge option. Use propane on the road like 99 percent of RVs do.
12v vs 6v points are moot once you move to AGM. I recommend Lifeline deep cycle in the shape that fits the most amp/hrs in the space. No difference in construction, very low fail rate.
Next would be to review your charging system to minimize generator run time. Solar is great however if running the generator you want 60+ amps at 14.4 volts into the Lifeline. Flooded you want 14.8 volts again at 60+ amps. Other AGM is good too but check the charging specs.
PD9280C - 14.4 volts
PD 9280C - 14.8 volts
time2roll wrote:
Read through them all? How about post your concerns related to your camping style.
Space concerns, how will you charge them... throw us a bone for what you need.
Otherwise you have read all the general answers.... go down and buy something. Unless you are going lithium not much has changed in 25+ years.
2oldman wrote:
6v v 12 2017
12v vs 6v.. which charge faster? 2014
12v or 6 Dec 2013
2- 12v or 6v June 2013
12v vs 6v batteries 2013
12v vs 6v batteries 2006
More 12v vs 6 2006
12v vs 6v 2010
Why 2 6? 2006
Anybody had one 6v fail?2010
maybe 12v is better 2010
12v vs 6v Feb 2010
It depends.
