sarhvac1
Mar 03, 2017Explorer
7.3 repair bill ouch
had my 7.3 to the dealer for Waste Gate actuator and heater fan stuck on defrost,,, $963.00 later runs like a champ. still cheaper than a new truck payment ok rant over!!
Stefonius wrote:hone eagle wrote:Any mechanic who thinks it's a good idea to hack my frame apart to avoid a few hours' labor is going to get slapped silly. A chopped and welded crossmember will never be as strong as the original.Wild Card wrote:Local farm repair shops just cut the offering crossmember ,replace pan and weld it all back together.Stefonius wrote:Negative ghost rider. Step #1 is remove engine from frame.
OP, I feel your pain. I'm about to open my wallet to have the oil pan on my 7.3 replaced. Most of my work is DIY, but for pan replacement I keep getting stuck on "Step 1: Remove cab from frame".
Farmers fix. quik,cheap but it will end up a little heavier.
I found a shop locally who will do the whole job for about $1,400.00. They remove the radiator support and pull the engine from the front. Not a bad deal.
