ShinerBock
Jun 04, 2021Explorer
Bionic Man wrote:ShinerBock wrote:
I had a work truck 5.0L and later a work truck Ecoboost and they both got the same crappy fuel mileage towing the same exact same trailer. My personal F150 got no different fuel economy than a good friend mine 5.7L Hemi towing roughly the same load (Jeep and gear) down the same roads from Texas to Utah. The only difference was that his engine was huffing and puffing a little more the higher we went while I hardly felt any difference in power.
In my experience, turbocharged gassers get the same horrible fuel mileage when towing as a larger displacement engine with comparable power. More air equals more fuel and a turbocharger increases the amount of air being pushed through the engine just like increasing an engine's displacement does. The only difference is that you can go back to a smaller displacement when you don't need all that air(boost) in a turbocharged vehicle, but can't with a N/A engine of a larger displacment unless it has cylinder dectivatiuon.
I’ll just tell you point blank that hasn’t been my experience. While towing my wake boat, my EcoBoost Expedition gets at least 20% worse MPG than the Yukon 6.2 it replaced. It’s considerably worse when you compare it towing my 17’ fishing boat. Just about everyone on the boating forums I frequent say the same thing.
I’ll also say that the towing experience as well as speed over the passes is better in the EcoBoost than the 6.2. It holds speeds up the passes that the 6.2 simply couldn’t do.
I’m pretty comfortable saying a EcoBoost type engine gets slightly better MPG when solo and quite a bit worse MPG when towing. Which overall is a win in a vehicle that doesn’t tow frequently. But that isn’t what a 7.3 is designed for. It’s designed to be a work truck and if Ford added turbos it would suck fuel like a drunken sailor. The loaded MPG in a vehicle that is designed to spend a lot of time loaded would just make it highly impractical.
And FWIW, for my use in a full size SUV, I’d choose the EcoBoost over a 5.7 or 6.2. Just no way I’d consider it (or especially a super sized version of it) for a full time towing vehicle.
When Pickuptucks.com tested the Ecoboost versus the GM 6.2L, 5.7L Hemi, and Nissan 5.6L back in 2018, the Ecoboost got the best towing mileage and unloaded mileage. However, the 6.2L did get better fuel economy than the other two 5.xL engines when towing. I have read multiple reviews ad MPG loops the 6.2L even got better fuel economy than the smaller 5.3L when towing as well. I am not sure if it is the premium fuel requirement, but many tests I have seen showed the 3.5L Ecoboost and GM 6.2L neck and neck with each other on fuel economy when towing and both are generally better than the rest of the engines.
2018 Best Half-Ton Truck Challenge
