- tropical_ronExplorerI had a similar problem where the umbilical came loose behind my motorhome at the connection from the car 7 pin connector. My remedy is to use velcro strap to ensure that the connection stays firm. 5 years of worry free connection. My issue is the umbilical is heavy duty cable like used on trailer trucks and is very firm and always has spring tension. My fix works great for us. I use velcro straps at both ends of cable. Good luck.
- TvovExplorer IIIs the plug actually falling out of the connection, or coming loose and almost falling out? Most plug receptacles have a hinged cover that has a lip on it that will grab the plug, preventing it from falling all the way out.
A plug can still come a little loose, though, and also some of the connectors inside the plug can get worn.
But... with your trailer being so new, maybe the plug came from the factory defective? Replacing the plug may solve all your issues. - Road_RunnersExplorerIf all else fails replace the receptacle on your truck. I would suspect that the spring on the lid of your present receptacle is broken and won't hold the plug from the trailer firmly.
- Baja937Explorer
nevadanick wrote:
Your not pushing it in far enough. The flap or door has a stop built into it that the keeps the plug from coming out.
X2...You've got the same "Blade" type connector as I do on my 2014 Ram...
Make sure the trailer is a "Blade" also...
You're trying to spread the female blades open and insert the males...It's a tight squeeze so the connector stays on...Work it gently but push hard and it'll sit nicely...They mate real solidly...
There's some camp chatter for ya'!!! lol... - RoyBExplorer IIThey use to snap in place with strong lids with the older models trucks. I know my 2010 model Ford does not do this very good as well,
I use the small bungee cords to hold mine in place as well...
I just wrap the bungee cord around the cable an pull tight to hook into the two side eyelets that most of the trailer hitch receivers have.
Roy Ken - nevadanickExplorerYour not pushing it in far enough. The flap or door has a stop built into it that the keeps the plug from coming out.
- 10by32ExplorerI always secure mine with one of the mini bungee cords. Learned the Harry way what happens when it drags on the road for a while.
44,055 PostsLatest Activity: Dec 23, 2025
