mkirsch wrote:
It's not necessarily as simple as buying a cord with two male ends.
Palomino, for example, uses a different wiring scheme on the camper-side plug. I had to spend a couple hours with a 12V battery pack and some probes to figure out which pin went to which light on mine.
There is absolutely nothing wrong with the "screw on" plug ends. They are very well designed to keep the weather out.
If you're paranoid, just take the umbilical off and put it in the cab of the truck while the rig is parked for long term.
Jeff's comment:
Male on both ends is easy to find but this one is female on one end and male on the other end.
I cant imagine why a cord would be designed with a male on both ends. Perhaps its the female connector that looks like a male due to the housing but it is truly a female.
My suspicion is Jeff needs a standard cord. Not sure about how/why Palomino would be any different. Not saying they aren't but doesn't make any sense.
