SWO_Vette's avatar
SWO_Vette
8.1L Chevrolet Avalanche 2500
Anyone got one? How it work for you? I did not know they made them until recently.
  • Rear axle ratio has no effect on payload, it's 8600 lbs GVWR on all 2500's, giving you about 2000 lbs of payload capacity.
    Towing limits with the 8.1 are 10,500 and 17,000 GCWR for the 3.73 axle and 12,000 with 19,000 GCWR for 4.10 axle.
    The 8.1 was available in the Suburban/Avalanche from 2001-2006. 2004+ got a few nice upgrades including steering wheel audio controls, touch screen stereo with nav option and digital OnStar. 2001-2003 1/2 models had analog OnStar which is not upgradable and no longer works since the FCC gave carriers the OK to discontinue support for analog service 10 years ago.
    Sub/Avy's with the 8.1 also came with AutoRide (RPO Z55), which on the 2500's is NOT load leveling but magnetic ride control. Shocks are $250 EACH unless you bypass the AutoRide System and install regular shocks (I have KYBs).
    Also check the brake/fuel lines, GM vehicles from this era have uncoated steel lines, and if the truck has seen any winters one or more lines is probably ready to rust through. Classic Tube sells full sets of brake/fuel lines in pre-bent stainless.
    Right now I have 175k on my truck and the motor has never been opened, not even for valve cover gaskets. Seems like I've changed everything connected to the motor but the 8.1L runs strong.
    If you're looking to buy one of these, I'm happy to help with any specific questions. I'm the original owner on mine and I also have the factory repair manuals. I started looking at new trucks a few years ago, but honestly I like the SUV body for the 3rd row seating capability. That, and pretty soon trucks are going to be like boats....so expensive that the average guy will only be able to afford a used one.
  • still won't have much payload, unless it has the 4.10 rear end.
    my '07 5.3 Avy LS is pretty much a stripped down version with the 3.73 rear end.
    my payload is only 1357lbs.
  • Not an Avalanche, but I've got a 2500HD with an 8.1 & it'll pull my 11,000 lb 5th wheel up 8% grades at the speed limit without too much trouble. But oh, does it ever love to drink.
    I think the 8.1 was discontinued around 2006 or so.
  • It will pull a boxcar up a tree if the bark stays on but expect frequent fuel stops when towing.
