Rear drums a bit loose. 5-6 clicks......not much.
Cable, definitely stretched! Moved the nut over an inch! Pedal is not at the floor, but a bit off. ALong with one can feel the brakes engaging as you push the pedal down. Will see how it works on my dads driveway tomorrow evening. 10' rise in 30-32' horizontal run. Part in middle is a bit steeper than the actual rise over run will net tho!
Along with rotating tires for the first time in 35K miles! Rears were a bit more worn than the front. Left rear worst than right rear. Probably due to the open diff, and that tire spinning more than the other........
Marty
