Allnew2this's avatar
Allnew2this
'90 Chevy 1/2 Ton 305 V8
I recently bought a 1990 shortbed Chevy truck, and I'd like to get a camper for it. I found a shortbed camper that fits perfectly, but I'm worried about the weight capacity. I would really appreciate some feedback on whether or not it's safe. I know there are a lot of threads out there with this same kind of question, but I couldn't seem to find any info that would help someone very new to this (me).
Here are some pictures of the camper. Thanks so much for your help!
  • i had 90 extended cab long box 1/2 and the 6,400 gvw sounds about right.. i know it would haul that camper around it might not like it... i used to haul scrap in mine even had 2 tons on it once.. so i know they will move the weight.. if your going to haul it i would recomend getting some 16" wheels and some d range tires...
  • sabconsulting wrote:
    Fred's advice above is good.
    The 'dry weight' a camper is advertised at can often be optimistically low. It probably also excludes the weight of batteries and propane cylinders, plus typically any accessories the original owner ordered with the camper or added afterwards as well as the things Fred mentioned - all adds up to a lot of extra weight. Remember there is also the weight of you, family, gasoline, tools, etc.
    People are typically shocked to realise: 1) These campers weigh that much? and 2) Is that all my truck is rated to carry?
    Steve.
    #2 is going to be the problem. I had an 89 half ton Chevy. The GVWR was under 7, I'm thinking 6400. I can also tell you that old 305 is not going to like pushing that box very well.
  • Fred's advice above is good.
    Steve.
  • Take the truck to a scale. Sometimes they are at moving van company lots, and they can check the weight for about $10. Some larger truck stops have them called CAT scale, also about $10. Check the GVWR for your truck on the inside of the drivers door. Subtract the curb weight from the GVWR, and see how much weight you can carry.
    If the camper is about 1,200 pounds empty, it might work, but if it has a 20 gallon fresh wate tank (160 pounds) a refrigerator that will hold 50 pounds or so of food, and your clothes, bedding, and passengers all add up to about 500 pounds more stuff. That will increase the curb weight by about 2,000 pounds. If your GVWR is say 7,700 pounds and the curb weight is less than 5,500 pounds, it will work fine. But I don't think it will work very well. You will have to check it and see.
    I had a F-350 with a 460" engine in it, single rear wheels and 9,600 pound GVWR. It was fine, andsettled down 4" when the 2,200 pound camper was on the back. It did not sway excessively in the turns, and still had the capacity to tow a trailer with a light dune buggy on it. Your results should vary.
    Fred.
